Results 1 to 15 of 17
Thread: Goggle fogging.
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Goggle fogging.
    I had a terrible problem with this the last race, infact the hot lap for the final I could barely see through them. Before we lined up I had to stop and rub the insides of them to get where I could see. Are there any products I can spray or coat them with to eliminate this from happening again?
    Pennsylvannia
    1,147
    They make special 2 layer lenses for paintball that do not fog. Paintball goggles are not much different than riding goggles, maybe they will work for you?
    There are also quite a few soutions/sprays out there for paintball goggles and windows that prevent them from fogging.. look into it. I have some JT anti fog spray for paintball and it works pretty well. Its cheap too.
    springville, PA
    6,185
    scott usa anti-fog cleaner is what my buddy always carries in his truck for his glasses/goggles. Works real well
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    bp739's Avatar
    bp739 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2006
    Southwest,Pa
    297
    Well this is gonna sound CRAZY but it WORKS............Johnsons Baby Shampoo....dilute some of it with water....smear it on the inside of your lens...and then wipe it off with a paper towel...it really works...and its CHEAP
    85' YAMAHA TRI-Z
    85'
    HONDA ATC 250R
    85' HONDA ATC 350X
    86' HONDA ATC 200X
    05' KAWASAKI KFX 700
    springville, PA
    6,185
    Nate
    R.I.P HRR
    Michigan
    1,220
    Toothpaste, hand soap also work in a pinch as well as spit
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Jul 2006
    go faSt!!!
    Jan 2005
    RI
    2,530
    the correct name for paintball lenses are thermal lenses. You actually give me an idea. The old JT Pro Flex goggles I have may fit in my helmet face opening.
    Then again, I MIGHT have used them for goggles when I sandblasted my 200s frame...
    Mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    hock a big lugeie in them and smear it around like scuba goggles! Bahahaha
    them anti fog lenses are the ticket,, coupled with the spray....
    lokisbuddy's Avatar
    lokisbuddy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    michigan, oscoda
    429
    i can verify the tooth paste deal it works on my paintball goggles and dive mask
    but on the dive mask it makes your eyes water for some reason
    May 2005
    Dorset United Kingdom
    1,408
    The double lenses will work the best.
    I need to do something with mine, Fogging up as soon as you stop going fast...my answer...... GO FASTER . Im gonna give soap a try.
    85 Tri-Z "Rumble Bee"
    85 250R "Red Rocket"
    83 200X "Flat Tracker"
    Aug 2005
    Portland Or
    412
    goggle foggin...sounds kinda dirty dudnit...when I played hockey I had a plexi face shield and the spray worked well. oakely actually makes a pair of goggles for the military that have a AAA battery that heats the lense just enough to prevent condensation. Theyre pretty sweet but spendy as oakley always is. 3 dollar spray is the best. I hate to think about the residue that toothpaste or soap or what ever might cause. eewww.
    "Always do sober what you said you'd do drunk. That will teach you to keep your mouth shut."-Ernest Hemmingway
    Nov 2001
    B.C.
    933
    Hit the local auto parts store and buy a bottle of Foggone. Works great....
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    Pennsylvannia
    1,147
    Quote Originally Posted by DeePa
    Mike
    Ahh yes. I was having a brain fart. I haven't paintballed in a few months and I'm beginning to have withdrawals..
