Originally Posted by
Trikeaholic
petcock, well, I was having a problem with my 350X petcock leaking. It is riveted together at the factory, but I drilled out the rivets CAREFULLY! and replaced the o-ring with one from an o-ring kit. I then used some thread rolling screws to put it back together and now no leaks. I have no problems with the one on my 83 R, so I cannot be sure if it is the same type or not. The point is that it should be fixable, if leaking is your problem.
Mine is riveted together also and that sounds like a great idea. Because leaking is my problem. I will give it a shot. Thanks
BigRed Forever, I am in richfield MN- HOw about yourself. Where are you located
84 Honda 250R air
84 Honda 200
71 Honda CT70H
01 Yamaha Blaster
88 Arcticat El Tigre 5000
85 Skidoo 440
