Thread: TRI-Z rear shock swap
    Mar 2007
    lakeville ma
    605
    Does any 1 know what's involved in putting a warrior rear shock in my z,i imagine it's pretty strait foward but i figured i would ask befor i bought 1, or does any 1 know a shock off a different quad that would fit better? thank's in advance
    thats the best one for a direct bolt in.. only thing is the resivor will not fit in the stock resivor holder..2 hose clamps does the trick.
    Mar 2007
    lakeville ma
    605
    thank's alot Bryan, seem's like your a tri-z god! hey on the outer water pump impeller on my z is that suppose to b a snug fit?i think so but i was fooling around with my clutch 2 day and relized it was spining free on the shaft ,the inside looks all whored out so i left it apart, i think i'll make a stake to hold it to the shaft
    also do you know if a banshee or warrior rear axle fit my z?
    banshee axle is the same axle.. make shure that plastic impeller did not come off the shaft. if it's spinning on it replace it. pull the impeller cover off the clutch case and check it out.
