Results 1 to 8 of 8
Thread: Bolt on 350x performance
    Mar 2007
    Washington
    5
    Im running a stock 350x engine. what is the best combination of bolt on products available to boost performance without changing the engine internally?
    Any suggestions heplful. thanks
    traxxasx's Avatar
    traxxasx is offline Alligator sized brain can't spell you correctly. Arm chair racerRoostin Away
    Sep 2005
    las vegas
    1,184
    suppertrapp exhaust, 2 stage uni filter, no aire box lid, and jetted to match. thats the best bolt on.
    MY FEEDBACK---
    http://www.pbnation.com/showthread.p...2#post20992142
    +6 positive feedback.
    WaLLa BinG WaLLa BoOm ShE's DoNe!!!
    MY 225 Dx
    Piped, jetted, 2 stage uni, wheel spacers.
    __________________________________
    My 82 250R
    All original even with tool kit.
    Stage 2 uni, no air box jetted.
    Mar 2007
    Washington
    5
    Thanks alot. Would it be advantageous to put a 38mm mikuni carb on too or not?
    Everyone seems to like the 400EX carb with the accel. pump along with any kind of exhaust upgrade.
    I have the 400EX carb and a TRX450R silencer and will post the results when I get it all dialed in....
    Mar 2007
    Washington
    5
    Does the 400ex carb fit the stock air box and intake boots or will I have to make a few modifications?
    Thanks
    I believe it is a direct bolt on, I have both carbs and if I get a chance I'll measure them later today....
    Back in Happy Valley
    833
    I was wondering what advantages there are to the accel pump on the 400ex carb. Does it just simply run better with better throttle response? I'm not too familiar with this set up and its function...
    86 350X
    85 350X daily rider
    LC 250R
    85 T3
    86 T3 roller
    85 250sx beater
    Baltimore, MD
    6,088
    Anytime you can change a carb to a carb with an accel pump, than it is a good mod. You have a more instant throttle response than with a non accel pump carb. Hopefull on the 400ex there is an adjustment for the accel pump so you don't flood the carb though.
