Thread: artic cat computer
    Feb 2007
    sioux falls SD
    59
    artic cat computer
    hey guys well ive been having a problem with my sled after riding for about 5 mins it blows the ecu/efi power fuse.
    i suspect the computer is fried.
    i was just wondering if any body had a computer lying around or know of one for this sled. its a 95-96 artic cat zr580 efi. the only ecu's that will work hav to hav one of the following code numbers on them
    3004-667
    3004-994
    3004-932
    oh and it has to be a blue dot ecu
    thnks guys
    Mar 2005
    overton, PA
    5,257
    hey man i had the 97 580 efi after runnign it out fo fuel too many times it actualy created a glitch inthe computor and it woudl run verry eraticaly.and would blow fuses now and then.
    Feb 2007
    sioux falls SD
    59
    how did you fix the problem with the glitch is there a way to reset the ecu
    joe_f7's Avatar
    joe_f7 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2008
    SE wisconsin
    227
    what sled is it off of? sounds like a stator or voltage regulator problem.
    1986 Kawasaki KXT 250 tecate
    ported, FMF pipe, DG silencer, boysen stage II reeds, 39mm keihin PWK, T4 thumb throttle and front master
    tbirdscott's Avatar
    tbirdscott is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2007
    Prince George B.C.
    216
    I agree sounds like a voltage regulator or bad ground.
    Scott
