Results 1 to 11 of 11
Thread: honda 250sx electrical
    Feb 2007
    louisiana
    28
    hey guys once again i have a question. i think i finally figured my problem sorta. i have a new spark plug. and two coils. i figure one has to be good. they have worked before. though it only fires sometimes and it is weak. i can hold the plug in my hand and it wont shock me. so does anyone know what my problem can be. i have many extra electrical parts. is it the rectifier? the previous owner said when it died it did like it ran out of gas. i am thinking that something went out in the electrical system and he thought it ran out of gas. any help would be greatly appreciated.
    1985 HONDA 250SX (in progress)
    1999 HONDA FFOREMAN 450S
    1985 HONDA SHAWDOW 500 (sold)
    springville, PA
    6,185
    Rectifier is to ensure the headlight doesnt blow.
    Check the CDI. I had mine go on a poker run and it was like it ran outta gas. If it the CDI it wont have ANY spark
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Feb 2007
    louisiana
    28
    cdi is that the ignition control thing?
    Feb 2007
    louisiana
    28
    where is the cdi located?
    Minnesota
    451
    its under the left side panel (left side of rear fender on a sx i suppose), its a little black box with a clear/white plug going into the bottom of it.
    1985 Honda 250es "Big Red" 1984 Honda 200s (Sold)
    1984 Honda 125m 1986 Honda 200x (new project)
    2003 Raptor 660 1978 Suzuki GS1000
    Mounts onto the battery box. Right there is where the wires break, at that plastic connector.
    Easy stuff first, on/off, wire, key switch etc etc...
    Feb 2007
    louisiana
    28
    i have spark sometimes. sometimes it wont spark. any ideas on what my problem could be.
    Sounds easy, like a bad connection....
    Feb 2007
    louisiana
    28
    any idea were
    Like I said, your gonna have to 1st get a wiring diagram. That will show you hoe to jump the key sw. and the on/off sw. Then check every connection besides those 2. Don't feel so overwhelmed there are very few connections between the CDI, coil etc etc.
    You HAVE to get a manual and check all the resistance readings and Ohmm out the wires - piece of cake!
    mark38090's Avatar
    mark38090 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Hawthorne, Florida
    354
    On my SX, I had the same problem. Someone on here told me to bang the CDI on a hard table and try it. It worked, everytime it wouldn't start I would beat the crap out of it on my work bench and I would get fire, if just for a few minutes. I picked up a CDI off of Ebay for $20 and haven't had a problem since.
    1984 Honda TRX200
    1985 Yamaha 200ERN ( two of these now)
    1985 Honda 250SX
    1991 Suzuki LT230
    2003 Honda Rancher 350ES
