Thread: 1984 Yamaha 225dx clutch question
    Mar 2007
    albany
    3
    My Yamaha 225dx 3 wheeler worked fine about 2 years ago. I haven't driven it since then and now the centrifical clutch slips. I took it apart and everything seems to be in ok shape? The one way bearing is working and there's about
    .075" of pad left per side. I can tell its this clutch because while it's running you can look down the dip stick hole and see when its turning and not.
    Do these clutch pads get glazed and slip??
    I did change the oil before this happened, would that do it?? ( I used 10w30 SE)
    Any suggestions?
    Curly
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    to the board!
    Use the search Bar it is very useful.
    Do you have a Manual?
    Now we need pic.
    Mar 2007
    albany
    3
    I don't have a manual
    traxxasx's Avatar
    traxxasx is offline Alligator sized brain can't spell you correctly. Arm chair racerRoostin Away
    Sep 2005
    las vegas
    1,184
    just run it hard, it probably is doing that cause it sat for so long, just run it hard and see if it goes away. or change *Edited**Edited* oil to just regular no se.
    MY FEEDBACK---
    http://www.pbnation.com/showthread.p...2#post20992142
    +6 positive feedback.
    WaLLa BinG WaLLa BoOm ShE's DoNe!!!
    MY 225 Dx
    Piped, jetted, 2 stage uni, wheel spacers.
    __________________________________
    My 82 250R
    All original even with tool kit.
    Stage 2 uni, no air box jetted.
    Mar 2007
    albany
    3
    That would be easy enough, I'll run the crap of it and see what happens.
    I'd add a picture to my post but it would take a light year or so.
    Thanks -
