What should I buy for my 350x a bigger tire or smaller. Iam using a 9" rim. Looking for some advice before I buy.
well first tell us what kind of riding you do... is ground clearance an issue? or do you want stability?? combo of both?? we need more info please![]()
86 200x
72? US90
79 ATC70
83 ATC70
84 ATC70
I ride on trails, ground clearance is not so much an issure. I was thinking about a 18x10x9 tire. Not sure how it changes to go with this tire.
i got both 20s and 18s for my 200x, the 18s are fun if your playing in a field or oval track, BUT you loose alot of topend and alot of ground clearance, i hang up on alot of things on the trails, but i am more stable in the corners with them, now my 20s are the better all around tire, they do everything good, while the 18s only do somethings good
I have a 350x with 22" oem tires. From experience, you wont go far through the trails with a set of 18"s.
Im going to be replacing my stockers with some 22" holeshots here shortly.
I run 22" Maxxis All-Traks. Some will say 22" tires are too big, but a 350X torquey motor can turn them. If you need more low-end, regear. The clearance and traction are great on these tires.
Honda
86 350X - Full Restomod
85 250R - Legend
85 Big Red - Clean Original
85 Big Red - Custom
Not Honda
85 Yam Badger 80 - Kids
99 Pol Sport 400 - Got it FREE
