Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 39
Thread: How to: Tapered headset bearings
    NE Arkansas
    2,344
    I have searched for info on this and have not found much. So, at my expense of 2 sets of these bearings, I tackled it and will share the procedure for completing the task.
    This is on my 85 Big Red, but would apply to many others. The bearing is the tapered bearing kit from All Balls, it comes with 2 bearings, 2 races, 2 sealing washers, and a spacer washer (it's placement is critical to the bearings working right.)
    First, of course, is to remove the triple from the trike and knock out the old races out of the frame.
    The new races will go in with the small ends pointing at each other. The bottom one will have to be driven into the frame. The top one goes in much easier.
    Top:
    Bottom:
    Next is to drive the bottom bearing piece off of the triple stem, it is pictured with the screwdriver pointing at it.
    It will look like this when you get done. Trust me it DOES come off, PITA though, hehe.
    Next is to grease the new bearings and place the bottom bearing on the stem. THIS IS WHERE I MESSED UP! The washer that comes with the kit goes ON THE BOTTOM FIRST! hehe. Place the washer on, then the sealing washer, then the bearing with the tapered end pointing up. You will have to drive the bearing on. Use a piece of pipe or something to drive the inner part of the race down. Here is a pic of what I did. I forgot the washer underneath the bearing, so now I have to buy another set because the bearing will be destroyed when I try to take it off.
    Install the top bearing in the frame with the tapered end down and the sealing washer on top of it, like so.
    Now you are ready to put the triple back on the frame, tighten the nut down, and put the trike back together again.
    The hardest thing of the job is getting the old bearing part off of the triple stem base. It took me about 20 minutes of prying and banging and cussing, but it came off!
    This is how I did it, it may not be 100% correct, but it's my attempt to help others learn from my mistakes!
    Later,
    Travis
    My Rags
    Solid Snake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    Lancaster, PA
    316
    Awesome thread man, I bookmarked this for when this gets done to our trikes. Thanks for the info and pics.
    Trikes
    1984 Honda 200x, 1984 Honda 200m
    Bikes
    1995 Honda CR125R, 1985 Honda XL100 (gone), 1982 Kawisaki KZ550 LTD,
    2001 Yamaha TT-R 125L, 1983 Honda XL185S (current project), 2001 Suzuki SV650S
    Jul 2006
    western ny
    3,366
    man thanks i was wondering how to do this. now i might actually but the kit.
    GIT IT RAAAGGGGG !!!!
    Minnesota
    451
    I wonder if you were real carful if you could split that old bearing piece of the tripple clamp with a air and chissle? Ive taken other bearing off like this, crack them in two and pick up the pieces!
    1985 Honda 250es "Big Red" 1984 Honda 200s (Sold)
    1984 Honda 125m 1986 Honda 200x (new project)
    2003 Raptor 660 1978 Suzuki GS1000
    NE Arkansas
    2,344
    I bet you could, and it sure would be worth a try!
    My Rags
    NE Arkansas
    2,344
    Ok, after ruining the bottom bearing to remove and ordering a new set, here is the correct way to put the bottom bearing on.
    So, the order from top to bottom is:
    Stem nut
    sealing washer
    top bearing (taper down)
    top race
    bottom race
    bottom bearing (taper up)
    sealing washer
    washer (included in bearing set, I used 2 and it worked ok)
    That's it!!! It feels like butter now, and no slack anymore.
    Not too big of a job, but a pain to figure out.
    Travis
    My Rags
    Phoenix, AZ.
    6,719
    I'm doing this to three of my trikes probably this weekend (250sx, 200x and 70). I hadn't really thought about it, assuming it would be pretty self explanatory but I probably would have screwed one of them up before getting it right. Thanks for screwing up before I could.
    Pa.'s Highest City
    8,058
    Are those bottom bearings pressed on? I'm having a heck of a time getting them off to change them out. This is a tri z if that matters at all.
    What pisses me off is that the manufacturer doesn't give a simply blowup picture of the proper installation order?? I'd be calling them up and bitching for a free lowerer bearing, thats simply not fair to the consumer.
    NE Arkansas
    2,344
    Chris, yeah the bottom bearing has to be pressed on, I had to beat this on, carefully. And eyeball and measure how deep the lower race is in the frame to make sure that the washer will be enough spacing. I shoulda just used 1 washer, but when I eyeballed it, it looked like it needed more space.
    , good luck with the 3 sets.
    Dirtcrasher, you're right, a simple diaghram would be helpful, hehe.
    Oh well, I have a new upper bearing and upper and lower races if anyone needs em.
    My Rags
    Mar 2005
    Parma. Oh-sub of Cleveland
    472
    yeah.. i had to do some of those.. the bottom bearing must be pounded on.. i just cut my old set off.. caution!! lol if you cut it off dont cut the stem, you'll be screwed.
    1985 350x
    1985 Tri-Z
    1983 200
    Atc 70
    1985 200s
    -parts for sale
    1985 Polaris Indy 500
    1986 Polaris Indy 400 liquid-For Sale
    1988 GMC sierra 1500
    82300R is offline Got The Holeshot Arm chair racerJust too addicted
    Dec 2005
    cobbwebs in your mind
    1,058
    when i changed to the same kind of bearings in my old 81 r, i got the one on the stem all the way down to the stock race before i realized that it had to come off. carefully got the new bearings back off, then the fun part of getting the old race off the stem. it did test my patience. but it all worked. some basic instructions with the bearings would have helped alot.
    I got a roll a quarters an making change !
    Phoenix, AZ.
    6,719
    Well I already screwed up and I haven't even gotten as far as putting the new set on. I couldn't get the stupid lower race off so I took the dremel to it and ended up cutting a nice little groove in the steering stem about 2mm deep and 1 centimeter long. I hate those little bastards.
    Pa.'s Highest City
    8,058
    Quote Originally Posted by Dammit!
    lol... I just saved myself the headache and dropped the trips along with the new bearings off at the local guy.. Only a couple bucks so it was well worth it.
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    It's funny you say that.
    My Moto is...
    A smart person learns from his own mistakes,but a genius learn's from others.
