I do the same thing and use a big Monkey Wrench to lock the outer nut. They must have a tool that a toque wrench fits into. Then there is a formula that has to be figured into the final torque because your pivot point is now a few inches away from the actual fastner.
The inner nut is what tightens the inner races of the axle bearings to each other, thats why the tube is in there so there is no sideload on the bearing when it's installed. Then I lock down the outer nut.
I worry about torques with heads and cylinders and internal motor parts. I really don't sweat the other stuff, thats just me though...
with normal roller bearing like that with the spacer between them i tighten the first nut tight since it doesn't create any drag if the spacer is fine.
then i crank the hell out of the 2nd
with taper bearings i just go hand tight or a little more then crank the hell out of the 2nd nut
2012.....Replaced the 350x motor for a 444cc YZ426 WWW.HREATV.COM
i use a cressint Wrench that they use on 18 wheelers. i get the nut torqued down pretty good with a wrench that is about 2 1/2 feet long and 20 pounds. but anyways you couldnt have to use a torque wrench because the outer nut is more or less a jam nut.
WoeWA buddy .......... I might be misunderstanding you but you don't use that ( wrench that is about 2 1/2 feet long) on the inner nut do you?
The outer one is the one that you really crank on.
" YEA IM NUTS " ........if you do that way, well yea, you are!
To the others, thank you!
lol no not on the inner nut. well i do use it but i dont crank it down plus its the only wrench i have that opens wide enough to get on the nuts. plus that thing will break any nut loose and is very good for making a nut stay in place.
At The Back Of The Pack
Arm chair racerAt the back of the pack
Aug 2004
Houma Louisiana
388
Find the right size crowfoot wrench, attach it to your torque wrench and WALLAA! hehe DOes anyone know what size the nuts are? I thought they were either 2 1/16" or 2 1/8" dunno for sure. Dave
Here is what I use for my 350X axle nuts. My brother made them when he has access to a machine shop.
ATCnut
82 185s - sold
83 200x (hopped up)
84 200x (stock)
84 70 (lost this one to the DMV)
85 70 (soon to have lights, a foot brake, and CDI ignition)
84 200es (parts trike) - sold
85 350X (the best)
85 350X (siezed motor, dream of a poweroll kit someday)
85 250sx (frame was trash, got parted out)
86 250sx (the tractor)
86 250sx (a nicer tractor)
86 250sx (an even nicer tractor)
87 200x (parts trike, its really rough, a dog was chewing on it for a while)
87 250es Big Red (the tank!!)
