Results 1 to 10 of 10
Thread: case saver 1985 honda 250r
    Nov 2006
    Oregon
    55
    guys where can i buy a case saver for my 1985 honda 250r
    Aug 2005
    Portland Or
    412
    I got mine for 25 bucks from ESR. do a search theres a few threads with so good options. Shouldnt have to spend more than 25...you still have the tecate?
    "Always do sober what you said you'd do drunk. That will teach you to keep your mouth shut."-Ernest Hemmingway
    Oregon
    2,471
    I go with ESR Case Saver ....
    Nov 2006
    Oregon
    55
    i dont have the tecate anymore
    Phoenix, AZ.
    6,719
    There are two options better than ESR. One is starks machinery on ebay. The other is a friend of Speedbump here on the boards that makes one very similar to the starks. The main difference is they wrap around the shift shaft. Better protection.
    Aug 2005
    Portland Or
    412
    Looks kinda thin there above the "R" but I think they all do...after seeing how bount up a chain can get Im paranoid as hell. If I had it my way itd be a 3 inch steel block.....but Im a little
    Phoenix, AZ.
    6,719
    A little thin there but they're 1/4 inch deep. Much beefier than the others.
    Nov 2006
    Oregon
    55
    so what site has these ive looked on ebaqy but did not find any
    Phoenix, AZ.
    6,719
    Send a pm to Speedbump here on the boards.
    Jun 2004
    potsdam ny
    1,227
    i need to add 2 cents about case savers. first of all, the beefier the worse, think of what a case saver is made to do, create a "cushion" between the sprocket, chain and case. if your chain wants to come off, it will and it will do damage. what it damages is up to you. the beefier the case saver the less of a "cushion" you have, so if your chain comes off, its taking the case saver mounts with it, while the saver remains largely undamaged. i dont know about you, but i would rather buy a 20$ saver rather than a 300$ case half. if you get a mid-range case saver, you get best of two worlds, when the chain goes wild it will a) bend rather than hold on to the cases and snap the mounts off and b) it will help guide the chain instead of letting it bind up in front of the sprocket. so, in my strong opinion i would go with either a nac's case saver or an equally weak case saver, anything beefier is overkill.there is a reason why the serious racing ompanies don't offer an extremely beefy saver, only bling-bling companies.
