Originally Posted by
mudbogger
Finally got the camera fixed and had the time to start ripping into the new 250r-it is alittle rough but can be rehabbed.I have a series of questions for you guys:
1-the front headlight isnt a 85-what the heck year is it and can the internals be located from another machine in the same year-like a 250sx, etc?to fit new plastics for the 85-I do not like the 1 thats on here currently.
2-the jug appears to have some mild porting done to it,whats your view from the pictures, mabye just some light DREMEL work to the ports?
3-the motor kept on flooding out, badly, I checked the reeds after re-building the stock carb-they had such a gap in the I could put a .014 feeler guage between them-my question is the BOYSEEN rad valves, they work well and do you guys recommend them, or go carbon fiber?
4-the swinger looks to have had some welding done to it in the rear by the carrier, am I correct?
5-the stock intake and reed cage had no yamabond or adhesive between them,wouldn't that be cause for an airleak?Also, do you guys leakdown test your motors and if so, whats the norm for those as far as acceptable leakdown for minutes waited?
6-the rear sprocket hub-thats supposed to have threads in it correct?Mine doesnt as you can see in these pictures.What axles, hubs do most of you guys go with and whats the best place to buy them from, I would like to mabye go +2 at most, I ride heavily tight trails in the Northeast and rarely go to the dunes.
7-bearing carriers,RAD?durablue?
also, let me know what you think about the ride-I purchased it for 1200.00 not running, that story has been posted previously.
