I got it, I sent a reply. The only thing I do to my gaskets is spread oil on them and install, I don't use any bonding agent on any of them. I would stick with the oil your used to running. I do run amsoil, I think it burns cleaner.Originally Posted by mudbogger
I see someone used different bolts for your sprocket, they should thread in from the tire side on the 85 but if you get a new axle it will come with a new sprocket hub.
If you change out the carb to a 86 or newer I think you will get better throttle responce over that round slide. If you want a good woods bike get a 34/36mm carb, a 38/39mm will give you better top end.
