87 pump gas, go as low as you can. the lower the octane the more power, if you hear it knocking you need to go up in octane. some people mistakenly run racve gas in motor expecting to get more power when they actually lose it. race gas has additives that make it burn at different rates usually much slower than pump gas, most "race" engines have extremely high dynamic compression, which can make an engine work like a diesel if the fuel is ignited by pressure and heat (like a diesel) before the spark plug sparks, and when the spark plug does fire, that the sound you hear, the two explosions inside the combustion chamber colliding. so, when you motor starts sounding like a diesel, move up in octane, also you want to check your plugs to make sure they are staying in a comfortable range for riding around. if you just dont care about tuning or max power just run race gas...
