Results 1 to 2 of 2
Thread: how much oil do i put in the tranny
    Nov 2006
    Oregon
    55
    Guys i have a 1985 honda 250r and i would like to know how much oil i should put in the tranny or the case
    San Diego
    52
    I think its like around 24 oz.
    But if you take the little 10mm oil check bolt out, its on the same side as the fill cap, and put oil in until it starts to weep out I believe that's an accepted way to fill it properly.
    Maybe rotate the kick starter a couple times too as you do it so oil gets into yer clutch.
    good luck
    Born a Long time ago, in a garage far far away...
    The Green Monster!
