i was wondering whats the best adjustment on my 86 250sx. stiff susp. or loose susp. i mostly ride trails, mud, and hills. is it better to have stiff susp. for those riding conditions?
1986 Honda 250SX
From my knowledge (not alot) this is what I think, when your adjusting there is a number of adjustments. As for just adjusting what you have, you got your nitrogent gas pressure, and your shock tension compresor.
As for what both do, its just basicly trial and error to find out which is good. But I adjust he nitrogent so it takes up the slack for my weight, basicly just adjust it so that It doenst sag down alot, but its not like stepping onto a rock. The spring tensioner, is for rebuild and compression which keeps it from bottoming out.
Now for which is best, soft, or hard, If you jump alot (me) its good to have it more on the hard side to endure the hard landings, and keep the frame from splitting in half. You can how ever blow your nitrogen seals if its too tight, and too much compression.
If you dont jump that often, the looser you can get it, without botteming out, is better for woods and trails. Having it soft will help take the bumps, ruts, and help move your body around to control it.
Im probably totaly wrong, but oh well it got my post count up..![]()
<center><B>1)</B>1983 250r <B>2)</B>1984 200s <B>3)</B>1982 185s Rebuild Project.
.:: Building 86 250r or cr500r or cr250r or ... sigh ::.
.::Visit www.MidWestTrikers.com trikes! ::.</center>
Originally Posted by Instinctz
Not totaly wrong, your post counts up!but unless '86 is diff from '85, there is no nitrogen adj.. The only adjustment on my '85sx is a rotating spring compressor at bottom of shock w/4-5 different levels of tension. I weigh about 175 and have mine on 2nd lightest setting. Try them all, see what you like.
I would have run to garage and checked on # of settings but just got order from jlatvproducts.com ,today, in it was Shockwears shock cover 8)(didn't want to take it off to chk.) Chrome lug nuts 8) new frt. fender 8) and universal mud flaps :? (HOWDY, I need those oem flaps, any luck!)
So I know your all droolin' for pics! Here they are: :-P:-P
:-P
:-P
Al
TF03/HASPIN ACRES /BADLANDS SURVIVOR!!! -LIFE IS GOOD!!
'86 350x (latest addition)
'85 250sx-200x frt.end,350x bars,plastic tank,3"hub spacers,22x11x10 Fast-Trekkers/.190 Douglas Red Label alum. rims/PRM desert grab bar
'85 250sx(supertrap exhaust,chrome rims)
'87 200x(restored)-'85 200x-'84 200x
nice sx al! btw, i have a 225dr, and how do you adjust the tension? my dr has a big nut, and another nut. i can loosen the little nut, and the big one turns. should it click? what does your sx do?
My Rides
Yamaha 225 DR For Sale Soon
Yamaha 200E
Honda 110 Need parts? PM me! They're cheap!
Trikes are fun, trikes are fast. They make everyday a pure blast!
als250 is right, there is no nitrogen adjustment, there is a 5 step tension ring. im a big guy , 240lbs and 6ft 2in so i have it all the way up to make up the weight, i was just wondering if that was a good idea. thanks.
1986 Honda 250SX
