Thread: Rear Shock ATC250SX
    Mar 2007
    South Jersey
    3
    Rear Shock ATC250SX
    Hi all, does anyone know where I can get a replacement rear shock for an 85 atc250sx, or at the very least an original OEM part number? Thanks.
    Jan 2005
    Slatington PA
    4,372
    I see them on ebay a lot. You should be able to get one for 20,30 bucks or so.
    You sure don't want a new one at 300 bucks!
    SHOCK ABSORBER, RR.
    52400-HA6-003 001 $298.82
    What's wrong with yours?
    springville, PA
    6,185
    the shock is discontinued and would have been $360 according to bikebandit.com. Your best bet is either ebay, the classifieds here, or go aftermarket. For $313, Worksperformance.com makes them.
    Here is their shock list http://worksperformance.com/pdf/app_guide/atv.pdf. Look under the A/t Steerlers single
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Mar 2007
    South Jersey
    3
    Mines BEAT! It looks like the original from '85 and at my weight I'm needing something in good condition. Even with the pre-load dialed in half way it's bottoming out pretty hard going over the rough stuff.
    springville, PA
    6,185
    yeah they do that especially with my weight. My SX has the stock shock and the other has a works. Personally I like the way the stock one is unless for some reason I'm jumping it
    Nate
    R.I.P HRR
    mad_max is offline Just Too Addicted Arm chair racerJust too addicted
    Kansas
    462
    I wouldnt get a works unless you have a modified front suspension.
