Put a priming bulb from an outboard motor in the fuel line. Prim it till you have fuel at the carb then start it and keep squeezing it to keep it running. You might get lucky and the pump will work on its own. Before you do this I would make sure that all the lines are in good shape and that you don’t have an obstruction in the tank or lines.
Parts for sale
85 KX250 Roller with engine
KDX motor
2004 E-Ton Viper 50 Needs work
Honda 87 Fat Cat Roller
Honda 200m motor
Honda 110. 80 frame 82 motor For parts. Runs.
Honda 84 ATC 70 Roller Cheap.
XR75 complete bike
XR80 parts
Yamaha 225dx parts.
Honda 84 200es parts Good bottom end. (quad conversion front end)
Kawasaki 93 KX80 Motor (needs piston & bore)
Yamaha 88 YZ125 cases
Suzuki 85-87 LT230s 2 complete parts bikes.
Honda 83-85 200x Parts
Honda 86-87 200x Parts
