Question about the honda 200x clutch- Im unable to activate the clutch. I took the side cover off and found that the spring that puts tension the clutch cable came off-- Is there any trick to setting that up right???? The post that the spring goes on has a notch, where is that needed to be to operate the the clutch
Thanks for the help-- pull'n my hair out on this one!!!!
Eric
