Thread: Yamaha 1984 Tri Moto 200L Clutch Diagram Needed + a few questions
    timex69 is offline Just Too Addicted Arm chair racerJust too addicted
    Sep 2003
    Saskatchewan
    485
    Hey
    I've had this Yamaha 200L for quite some time and got it running a few months back but I cannot figure out why I cant adjust my clutches so i've come to the conclusion that i must be missing something. People claim to back the adjuster screw out for the clutches then turn it in until you feel tension but I cant feel any tension. Could someone tell me what this could be
    I need a scan of the clutch section out of a good repair manual (dont refer me to bike bandit as it doesnt give a close enough view), make sure it includes the adjustor and outside case so I can see if im missing something. If you dont want to post the scan up here my email address is alex_harman98@pei.sympatico.ca .
    Thanks
    Alex
    Dec 2005
    Wisconsin
    1,141
    Download the ytm-200 service manual from the 3WWforums homepage It's all there with instructions
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    Nov 2002
    Kirkville, NY
    3,831
    When the cover is off check the arm the adjuster is hooked to, I have had one crack on me when installing the cover. I would adjust the clutch but it still would not work, after I had the cover off a few times I saw the crack.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Sep 2003
    Saskatchewan
    485
    Hey
    The Fox:
    The adjuster arm was cracked, i just replaced it and im still having the same problem. I finally did what ive been meaning to do for along time. I bought a clymer manual for my trike. Apparently from what I read your secondary clutch housing cannot have many deep groves, and mine has about 4 really deep ones. So im going to need to replace that. My clutch plates in the primary are only fair so if i can find a decent set of used ones ill buy them or even a new pair because I beleive their only 50 dollars or so to replace I may as well get new ones.
    EDog: Your pm box is full, empty it and let me know so I can drop you a line on the parts I need.
    PS if anyone has any parts for this trike for sale let me know I am looking for alot of things. List what you have.
