Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 44
Thread: 250r rear brake mod
    PA
    3,515
    250r rear brake mod
    one thing my bro found out was that a newer yz front caliper will bolt on the rear of a 250r with some slight dremel work.
    plus you can use the yz rear master cly too and it is rock solid!
    here is how i made the mount for the master cly
    WWW.HREATV.COM
    Pennsylvannia
    1,147
    Ok I bought a YZ400 front caliper I believe, and when I went to put it on, the disc is too large to fit between the pads? How do I fix this? I don't know if you went through this or not..
    Jan 2005
    RI
    2,530
    Edit... First off...what YZ caliper are you talkign about. Can you give a more specific model and years of that model which will work? Im not too up to date with quads so that would really help me... Also, what is this slight dremel work needed to get the rear caliper on? Stock 250r Mounting bracket? Is it a dual or single piston caliper?
    Nouse, use c claps to completely compress the pistons and give it another shot. If not, you may have to grind a little of the brake pad away to get it to fit.
    Mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Pennsylvannia
    1,147
    Ok you were right. I didn't even look, but the pistons were out almost the whole way. I pushed them back in and it fit fine, but now the mounting plate for the caliper is too thick to allow it to fit between the disc and swingarm mount or whatever it is called. I can't get the mounting plate off of the caliper.. how do I do it?
    Jan 2005
    RI
    2,530
    the Mounting plate probably has apin that slides into the caliper. Maybe heat that pin up a little bit. What is the overall condition of the caliper? Looks kind of beat/rusty? If so, its probably frozen. Just heat it up or soak that pin with PB Blaster or your Favorite penetrating oil/aersol and give it a shot. Dont be afraid to give it a good tug to get that pin/bracket out. Just be really careful when using the heat or s.
    Mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    PA
    3,515
    i used like a 02 or so yz 4 stroke front caliper...they are all the same,and i used the stock 250r mount and it bolts right up if you oval the 2 holes a bit...ill get some pics soon
    oh and its a twin piston caliper
    WWW.HREATV.COM
    Sep 2003
    Elizabethtown PA
    1,581
    i'm the brother of swigin.
    i have a 98 yzf 400 front caliper on the back of my 86 trx 250r and you have to dremil out the holes more with this one. the caliper was spaced perfect i did not have to modify the yz bracket so you must have a stuck slider. i just egged out the hole and it bolted rite on.
    the 2002 yz front calipers like we used on the 350rx you do not have to do it as much. any model yz will work 125 250 2 stroke or 250 450 4 stroke they are all the same.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    Pennsylvannia
    1,147
    Its a very nice caliper.. no rust at all and it looks almost new (with the exception of a tiny bit of dirt from use that will wash right off).. the mounting plate is just a little too thick. I'll get pics later.
    Sep 2003
    Elizabethtown PA
    1,581
    Quote Originally Posted by nouseforaname90
    since you have a 85 250r that mite be the problem since they have the different mounting system from 86-89 atc/trx250r's
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    PA
    3,515
    heres some caliper pics
    as you can see you dont need to slot the mounting holes much since no hole is showing under the allen bolts
    and on some you need to grind a small amount off the mount under the rubber piece thats under the word nissin
    Attached Thumbnails Attached Thumbnails rear caliper 1.JPG   rear caliper 2.JPG   rear caliper 3.JPG   yz caliper.JPG
    WWW.HREATV.COM
    Pennsylvannia
    1,147
    There and by the mount hole in the front. Yours seems to be flat right there, and mine is not. I guess I'll just have to grind it down.
    kb200x's Avatar
    kb200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    KY
    295
    Quote Originally Posted by SWIGIN
    Is Nissin Stock Calipers for what?
    There reason I ask is I have Nissin calipers on the front and back of my 350x but I have no clue what they go to?
    86 350x "O' Smokey"
    83 200 auto X
    84 200x
    85 110
    82 70
    PA
    3,515
    nissin has bin around for decades ....so who knows
    WWW.HREATV.COM
    Jan 2005
    RI
    2,530
    just a note, if you have an 85 r, you need an 86 r rear caliper mount to make this work.
    mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Nov 2005
    New Jersey
    659
    The rear stainless line, is that for a 86 r or for the Yamaha application?
    OPPPS-I see you used the whole set-up sorry, can you just use the caliper without the master by chance?
    http://www.pilotodyssey.com/PO/index.php
    88 TRX LRD,39MM pwk,Durablue+4.Nice rider
    85 250r West Coast +4,Durablue +4,Boyesen rad valve,Keihin 39mm,Rad double row carrier
    86 250R west coast +4,Durablue+4,Maier plasitcs, Keihin, Boyesen,Wiseco big bore kit
    85 350x-all new everthing,trailer queen,all OEM-NOT FOR SALE!!
    4-FL400R HONDA PILOTS.See my section on the page!
    2-85 T-3 Tecates all the bells and whistles
    85 T-3 project trike in works
