Page 3 of 3 FirstFirst 1 2 3
Results 31 to 44 of 44
Thread: 250r rear brake mod
  1. #31
    Sep 2003
    Elizabethtown PA
    1,581
    man, im so confuzed! jason what where we discussing?
    i was saying you can by this yz caliper and do the swap. saves you some money since you only have to buy the caliper instaed of all the 450r stuff. the yz caliper is dual piston.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
  2. #32
    Jul 2006
    so I can put this yz caliper in place of the 450R caliper? becouse now I will be going to a complete 450r setup (swinger,carrier,axle)
  3. #33
    Sep 2003
    Elizabethtown PA
    1,581
    you put the yz caliper in place of your factory 250r one. just reuse all the rest. the 250r rotor is smaller which is better anyway.
    just trying to save a fellow 3ww member some coin
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
  4. #34
    Jul 2006
    ok what? the 250R disc will work on the 450R hub?
  5. #35
    Sep 2003
    Elizabethtown PA
    1,581
    i meant just keep all your 250r stuff and just buy a yz caliper to replace your stock 250r one. dont bother with the 450r stuff you wont need to buy any of it.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
  6. #36
    Jul 2006
    ohhh ok, man I was realy starting to get confused! didnt know what fit what and how!
  7. #37
    Sep 2003
    Elizabethtown PA
    1,581
    i know you can put the 450r swingarm and axle housing and all the 250r brake stuff will fit rite on.
    alot of guys posted on atvriders.com about putting 450r brake stuff onto the trx250r axle and housing and it bolts rite up.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
  8. #38
    Jul 2006
    so the 86 250R brake stay will go on a 450R carrier? man... this shyts getting comfusing!
  9. #39
    Sep 2003
    Elizabethtown PA
    1,581
    yes it will and you can use your rotor and hub ad the yz dual piston caliper them
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
  10. #40
    Jul 2006
    so I can officialy take the 450R brake stay and caliper off my want list now huh? and the disc hub will work on a 450R axle as well?
  11. #41
    Sep 2003
    Elizabethtown PA
    1,581
    yes it will. my buddy used my trx250r axle with all his 450r stuff while his lonestar was getting warretied
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
  12. #42
    Nov 2010
    Oshawa, On, Canada
    2,123
    Bump for wanting to know a specific guaranteed to fit year yz front caliper.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
  13. #43
    Nov 2010
    Oshawa, On, Canada
    2,123
    Just installed a 2002 yz125 front caliper on the rear of my 86 R, had to do a little filing, other than that it is a direct swap.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
  14. #44
    skidoo99 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    nh
    267
    this was a great thread, thanks for the info gents
    1973 70
    1984 70
    1986 250sx
    1986 250es
    1986 250r
