Results 1 to 15 of 17
Thread: 250x frame mod
    PA
    3,515
    250x frame mod
    i posted most of these before but now its done so ill post them here
    we have built around 6 of these and they realy hold up great.
    what i did here is add 2 inchs to a 250x/300ex frame and with a plus 2 swingarm it ends up the size of a 400ex
    Attached Thumbnails Attached Thumbnails 250x 1.JPG   250x 2.JPG   250x 3.JPG   250x 4.JPG   250x 5.JPG   250x 6.JPG
    WWW.HREATV.COM
    PA
    3,515
    i always lean the 2 tubes in front of the motor forward to make room for a shortened 350x header...plus i think it just looks cool...lol
    what we do is run 250r shocks on the front so thats why the shock mount wider and higher
    Attached Thumbnails Attached Thumbnails 250x 7.JPG   250x 8.JPG   250x 9.JPG   250x 10.JPG   250x shock mount.JPG   250x side shot.JPG
    WWW.HREATV.COM
    PA
    3,515
    ok got some more pics ...this 250x has a 350x motor and this shows how i like to make the rear upper motor mount.
    powroll and other places tell you to cut the cases so you dont have to change the frame at all but that makes your cases real weak....as i found out
    the first pic is the motor in my 350rx that had the cases cut to fit in a 250x frame....well it tore off since your cutting about 1/2 the rear mount away.
    this is after i fixed it but you get the point.....instead of cutting the motor to fit a 250x frame its better to change the frame
    the 3rd pic is just showing the oil cooler and the hard lines
    Attached Thumbnails Attached Thumbnails jack rear mount.JPG   frank motor.JPG   frank oil cooler.JPG   frank rear motor mount.JPG   frank rear mount.JPG
    WWW.HREATV.COM
    Dec 2006
    red neck land mn
    22
    do you have any more pixs of what it looks like from further away when its done so i could see the hole quad
    bandndesigns.com
    Feb 2006
    EC
    1,607
    Very impressive, swigin! I'd also like to see some "finished product" shots as well
    Baltimore---Charm City, or Harm City? Ask Pat.....
    PA
    3,515
    the red frame and the grey frame are two different bikes im building for people but here is a few pics of my buddy's bike that was built about 10 years ago
    he uses it hard and has had no frame cracks or breaks at all with these frame mods
    ill get pics of these two quads when they are done
    Attached Thumbnails Attached Thumbnails justin air.jpg   justin in air.jpg   justin over mid size double.jpg   side air dub.jpg
    WWW.HREATV.COM
    Feb 2006
    EC
    1,607
    Freaking incredible! I've got a 350X & it's insane quick & torquey. I can't imagine what it'd be like in a 250X frame, very, very cool! I'd love to ride one of your machines, do you sell any, or keep 'em in the family?
    PA
    3,515
    i sold one stretched 250x hybrid to a guy in maryland but that was my personal bike.
    i just build these when someone wants one....mostly friends and family but if you want one maybe we can work something out
    WWW.HREATV.COM
    Sep 2003
    Elizabethtown PA
    1,581
    Quote Originally Posted by the great gazoo View Post
    hey Great gazoo this is jason from Brapps ride in january.
    the red frame is going to be my quad. it's a 88 trx250x. it going to have a 250x in it biult up and the 250r front shocks and 400ex a arms with 450r spindles andn front end off Brapps 450r
    it's going to be having atc250r rear suspension alsowith a +2 swingarm.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    Newfoundland
    5,280
    Very cool stuff! Those look like a load of fun!
    Maryland
    3,077
    Can the 300ex engine still bolt into this frame?
    PA
    3,515
    yeah only the rear upper mount is widened so all you would need is a spacer to go back to a 250x/300ex motor
    WWW.HREATV.COM
    Sep 2003
    Elizabethtown PA
    1,581
    Quote Originally Posted by Louis Mielke View Post
    louis my brother could do the frame strech to your 300ex it makes them handle way better. with a plus 2 swinger it'll be the size of a 400ex
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    PA
    3,515
    Some more pics now that it's painted. the blue is a little light but it matches the works shock springs great.
    4th pic shows the decompression lever he is using instead of the automatic one
    the 5th pic shows the pro peg nerf bar mounts i made
    the last pic is the plus 2'' 250x swingarm made by hreatv.com
    Attached Thumbnails Attached Thumbnails Frontside.JPG   Close side.JPG   Front.JPG   Levers.JPG   Right Peg.JPG   Swing arm.JPG
    WWW.HREATV.COM
    PA
    3,515
    well, it looks like i have another stretched 250x to build.
    my neighbor just bought a stock 300ex and wants a 350x/stretched hybrid built......hopfully pics soon.
    WWW.HREATV.COM
