I put 40 miles on the DR today. I just never used neutral. W/ the neutral switch "hot wired" I put it between 1st and reverse to start it. The electric start worked perfactly. I never had the slightest problem w/ it!!! It ran great!!! I took about 50 pictures w/ my new digi cam, but I was the only 1 on a trike and I had the camera. I will post some stuck 4x4 pictures later.
The 200ern has a rigid rear end. the back of the motor looks alot different, it also has a completely different shifter linkage too. I do not think its a bolt in. I think I need to do some more reserch before I pull the 2 motors. I did use the stator cover from the E onto the DR, it went on w/o a problem.
I think I might just ride it as it is for now. My girlfriend is going to ride it alittle this summer and I will be on it till its dry enuff for the TECATE to come out.
MIK6 / Mike
New England Ride 4/13
