Both boots and the cable fit perfect.
People also sell 350X carbs for about 30$ versus the EBAY SX carb that can run about 80$.
The advantage is a larger inside bore, larger throttle valve or slide and the main jet is accessable from underneath the fuel bowl without removing the fuel bowl. If it's an 85 350X carb, it starts better than the 85 SX carb and if it's an 86 350X carb it is a great cold weather starting carb for the SX.
It is best to remove the airbox lid and put a performance exhaust on there to work with the 350X carb.
It does add quite a bit of go go.
