Results 1 to 10 of 10
Thread: stiff clutch 86 250r
    Aug 2006
    NW Ohio
    1,043
    the slutch on my 86 250r is really hard to pull in. ive checked the cable and lever and there good. i ordered an ez pull clutch lever. what could it be? would i be better off to buy a hydraulic clutch kit for it?
    ATC500AF
    Jun 2004
    Oregon
    1,782
    lol I feel your pain! I gave up on it and learned to deal with it..
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
    Jan 2005
    RI
    2,530
    Search for posts for the clutch update kit. Its a kit that replaces the clutch lifter and lifter bearing. The old single steel ball bearing can weld itself to the lifter arm and make for a realllly hard pull. Also, heavy duty springs make this condition worse, as well as a basket with grooves worn in the fingers.
    Has it ever had clutch work done?
    IF i were you, I'd pick up that update kit from honda, new friction plates and steel plates, a new hinson clutch basket, and a new gasket, and do it all at once.
    It will cost 200 for the basket, 75 for the kit, 75 for the clutch, and 15 for the gasket but combine all of that with a new perch and youll be good to go.
    Mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Aug 2006
    NW Ohio
    1,043
    thanks for the advice guys. but i should have deleted this post. my ez pull came in today and i hooked it up and the clutch is like butter now. but yes i was thinkin about that clutch update when i go to rebuild but thanks again for the advice.
    ATC500AF
    Dec 2006
    OZ
    132
    Quote Originally Posted by 200x newby
    im after one of these also do you know where I can find one?
    Oregon
    2,471
    Post some pictures of the new Hydraulic Clutch System !
    Nov 2006
    Florida
    1,663
    What brnad was that EZ pull clutch system you got?
    Aug 2006
    NW Ohio
    1,043
    here is the hydro. clutch kit its made from a company called MAGURA..... http://www.off-road.com/atv/projects...ura/index.html
    and here is the clutch kit i got cheap but effective its so easy to pull the clutch in now. i would buy from this place only because prices are low and shipping is fast..... http://cdbmotorsports.com/storefront...e5b58053417bc2
    ATC500AF
    Nov 2006
    Florida
    1,663
    I think they sell them on ebay too... I've heard of themon there but was unsure if they were any good.. Good to know now for future reference 200x! Thanks!
    Aug 2006
    NW Ohio
    1,043
    yes you can find both of them there. but for a cheap fix go with the ex pull lever. later i will upgarde to the hydro. i did not want to post the links to ebay as i did not want this gettin moved to the ebay forum.
    ATC500AF
