Results 1 to 9 of 9
Thread: Im about to stud my track. Any advice
    Duluth MN
    803
    Question Im about to stud my track. Any advice
    Im going to get them from DennisKirk. It my 90 Prowler 440. Im thinking 140 witch is 2 studs an inch, between the lugs in the shape of an arrow.
    any other ideas? I have never done this before so its all new to me.
    Confused As A Hungry Baby In A Topless Bar!!!
    '04 Honda CRF250R
    '82 Honda 200 4'sale soon
    '90 and '91 Arctic Cat Prowler 440
    '81 Kawasaki LTD 440 Belt Drive!!
    '92 Yamaha Warrior 350
    '05 DS 90
    Helmet save'd my friend's life, and mine, wear one!!!
    Trying is the first step to failure
    3ww Needs an iPhone app
    nate b is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Central WI
    433
    do you mainly trail ride, ride on lakes, race, is it stock. If its a stock trail rider 96-120 studs would probably be good for a 440. If you got the extra cash and think you need more go for 144, more studs you put in the more weight you got turning under there. get some tunnel protectors and a stud template and a track cutter and go to work.
    85 atc 250r;
    PSI porting & head mods
    fmf pipe & silencer
    boysen rad valve & reeds
    38mm air stryker
    Duluth MN
    803
    every year there is less and less snow. This yeah i only hit the trails ONCE due to lack of snow. Mostly, Im on the lakes. And im fish tailing all over the place. I never race, and its bone stock.
    '04 Honda CRF250R
    '05 DS 90
    Duluth MN
    803
    I found this. I can not get the pictures to work. Can anyone else?
    http://www.snowmobilefanatics.com/ar...sp?cid=2&aid=5
    '04 Honda CRF250R
    '05 DS 90
    oddball3's Avatar
    oddball3 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2004
    New Jersey
    224
    When you order the studs also order a stud template. It will help laying out the pattern and you will get the right scratch lines.
    IN MY GARAGE:
    1984 250r
    1986 350x
    1986 200x(wifes)
    1985 200x fixer upper
    1979 110 PARTING OUT
    1984 70
    http://www.hardcoresledder.com/forum...post&id=155447
    '97 ZRT 600 drag sled
    '97 ZRT 600 trail sled
    '98 ZR 440 sno-pro(wifes)
    http://www.hardcoresledder.com/forum...=post&id=79401
    Duluth MN
    803
    where does a tunnel protecter go? When i order, do I get one for each row of studs? I assume instructions will be included on mounting
    '04 Honda CRF250R
    '05 DS 90
    Central WI
    433
    tunnel protectors mount in the tunnel. they will come as a pair and will have instructions.
    85 atc 250r;
    fmf pipe & silencer
    38mm air stryker
    Jul 2006
    iowa
    451
    yea if you ride alot of lakes and dont plan to race, 144 should be good. me and my dad have always studded our own sleds and one thing we do is try to avoid putting the studs on the far outsides of the track, because they tend to rip out easier. you may or may not have this problem with your 440. And unless your pretty picky, you shouldnt really need a template. Its not too hard to get them pretty straight without one, we have done several tracks and never used one.
    InPiEcEs's Avatar
    InPiEcEs is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2004
    Northeast Wisconsin
    378
    I would go with 120 with your 440.........144+ will be a bit much.
    Got with 7mm studs, and aluminum backers.
    The template makes life pretty easy as afr as marking you holes, plus you aleays have one. Get ya a track drill as well.
    The most common 96 stud pattern is 2 per section, and if you go 120, you could go every other one 3, or every 4th one 4.
    144 would be 2 and 4 being a common one.
    The tunnel protectors go in your tunnel lining up with the windows in your track.
    They keep the studs from chewing your tunnel.
    As far s stud length, get some 1/4 inch taller than your lug height. Thats all you should need for general use. Any more, and you risk chewing your tunnel up.
    One piece at a time. Status: The Beast is Done..06-23-07
    Back in the saddle again
    Currently owned rides:
    My sleds, and.........
    1995 CBR600F3
    1976 Kaw 400 triple-smoker......SOLD
    1986 250R...owned since 1990
    06-23-07........the R is finally done!!!
    ESR pipe, Aktive reeds/CR cage, 38mm PWK, +4 Dominator
    mild clean-up porting, an open K&N, CR and YZ calipers.......among other things
