Results 1 to 8 of 8
Thread: blaster problems
    Air-cooled-R's Avatar
    Air-cooled-R is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2005
    West Monroe, LA
    167
    blaster problems
    wel. I've got my blaster running, kind of. It's been running pretty good, but yesterday and today, it hits but wont start. if it does, it doesnt run long. what could my problem be? thanks.
    My bikes:
    -1982 honda 250r
    -1999 HONDA 300 Fourtrax 4x4 "The Tank"
    -2001 harley 1200 sporty
    Oct 2005
    saratoga, ny
    2,819
    you sure your getting gas? you say you got it running, did you do a rebuild on it at all? are you getting spark? check your plug is it looking wet? i would check the carb, do a thourough cleaning and go from there. perhaps you need to up your jetting. do the simple thigns first. my blaster was a mutha to start at first when i did a rebuild on it, but i upped the main and pilot, and the thing purrs like a kitten now.
    TALLULAH,LA
    58
    I agree with Scooterroo sounds like you're carb needs cleaned or you need to rejet.
    Jul 2006
    fouled plug
    Sep 2005
    Massachusetts
    1,272
    Sounds like a problem I had with my IT200. I sheered my fly wheel key. It still had spark, and starts at times, but thats about it. Check that out.
    2000 Rm250
    1985 IT200
    2003 suzuki sv1000s
    2008 polaris outlaw 525s
    Rittman, Ohio
    6,276
    Quote Originally Posted by sykolincoln
    fouled plug
    Should be the first thing replaced on any bike that wont start, especially a two stroke. You should be carrying spare plugs when you ride.
    Aug 2006
    NW Ohio
    1,043
    yeah im with syko! my blaster always had fouled plugs durin the winter or colder months. go with a bosch platnum 4+.
    ATC500AF
    Oct 2005
    West Monroe, LA
    167
    the woodruff key in the flywheel's fine. Ive had that problem on other bikes before but its fine. I also tried 2 new plugs earlier. I'm pretty sure int's in the carb. I guess Ive just gotta play with it tomorrow. thanks guys.
    My bikes:
    -1982 honda 250r
