Change your tranny oil before you do anything! Get that tranny fluid out of there. A few things here. Your silencer most likely has nothing to do with backpressure, as its only a straight-through extension. It does not restrict airflow, but put it back on anyways. The best way to have a new trike and no place to ride is to piss of everybody in the surrounding square mile. A Z is plenty loud with a good working silencer. Second , get that tranny fuild out immediatly. What you are probably mistaking for a lack of low end is a clutch that wont smoothly engage. You start letting out the clutch and it grabs suddenly, and if youre not revved way up, it stalls. Just put any good name brand 10w40 OIL in there and youll be fine. Im partial to Syntec or other synthetic blends, but any 10W40 will suffice. Youll probably have to change it pretty quickly the first time till you get that other crap oil. Tranny fluid breaks down oil, and even small amounts will cause your oil to lose its viscosity. Tranny fuid is like 15w and should never be run in a crankcase. Do this before monkeying with any seals or anything else. Sounds like it has water in it, but since you dont know if they drove it through stream, or where it came from, start with clean oil, and see if it reoccurs. If it gets water in it again (gray oil) and you havent had it in water, the impeller seal is leaking.
FYI - The cooling system is positive pressure, and youll never get crank oil in the cooling system from a leaking seal, but youll get coolant in the crank. If you have oil in the cooling system, its coming through a leaking headgasket from the cylinder.
FYI - Banshee axle is interchangeable but its best to also get the Banshee locking nuts as the threaded part is wider, and the nuts are wider.
