Results 1 to 7 of 7
Thread: Banshee Axle On2 Tri-z??
    Mar 2007
    South Wales U.K.
    55
    I know for a lonestar axle 2+2 for a Banshee, does anyone know if it will fit a tri-z????
    Mar 2004
    North Central Ohio!!
    2,712
    Yes it will fit. It is a direct swap.
    Mar 2007
    South Wales U.K.
    55
    Thanks I'll buy it now i know!!!
    Jan 2004
    Palmetto,Florida
    2,300
    AHHHHH !!! i asked Moshman about that cause one day i'm gonna build the Flat Tracker TRI-Z ... +2's are like everywhere now for Banshee's "since there Pit Bikes now" !!
    "07" DR650 Suzuki Dual Sport
    Mar 2007
    South Wales U.K.
    55
    BAAAAAAAAA!!!! i was the winning bidder on the axle on the bay and the dude ended the auction early!!!!
    Nov 2006
    southern oregon
    2,338
    Quote Originally Posted by Tri-z addict
    That sucks... The seller probably realized that the axle also fits on a TRI-Z...lol....
    2-stroke lover
    na
    5,702
    Sorry Ronnie,I forgot to even get back to you on that.Banshee axles will fit.Banshee sprocket hubs will also fit.The tri-z brake rotor hub has to be changed over to the banshee axle.No other brake rotor hub fits the tri-z carrier.It will hit and grind on the carrier.Aftermarket blaster axles go right in the tri-z as well.Sometimes you can find a durablue from a blaster cheaper than a shee axle.Stock blaster axles may not fit perfect, cuz they run a wierd floating brake rotor hub set-up.I have not tried a stock blaster axle cuz they are shorter in width,But I run a Durablue blaster axle in my shee and was direct swap.Rocky mountain atv sells G-force banshee axles for 200 bucks brand new.You can go that route Triz Addict.
    I also had stated that 04 Yfz 450 rear brake rotors will fit on the Tri-z.They Will but you have to Strecth the mounting holes of the Yfz Brake rotor.They are slightly too small to fit perfect.You will also have to Shim the rear caliper out 3/8ths of an inch to meet the offset of the 450 rear rotor
    06 and up yfz 450s run a new rotor that WILL not fit the tri-z brake hub.
    I think a few years of the raptors run the same rotor as the Yfz 450 But I have not checked on that 100 percent yet.
    Billy Golightly has a yfz 450 axle in his Tri-z but they had to machine the carrier or brake rotor hub to get it to work.I dont remember the details of that mod,But it took some reworking to make it happen.
    Proudly NOT a member of
    "Team on the Teat"
