Ok I need some advise,
I have purchased 2 185s trikes and have been going through them thinking I would make 1 good machine out of the 2 and sell the other. Tonight I was riding the one I have decided to keep around and its real strong other then a real bad slapping noise comming from the head. The guy I bought it from said it was probably the timing chain. It doesnt smoke at all and idles great. Now heres the issue, I tested the compression and all three times I did so I got a reading of 60lbs so I thought I would check the other motor just to see how it compares and it had 75 on two of the three tests and 90 on another. The problem is, the motor that has the higher compression runs like crap lol. Im sure that its just simple stuff to fix it but to keep the higher compression bike would mean a complete swap of everything from one bike to the other
So I guess my question is, first what is the compression supposed to be on an 83 185s and is 15lbs difference in reading a dramatic difference.
Thanks again for the help
