Results 1 to 8 of 8
Thread: 200X starting trouble!!!!
    Aug 2004
    Idaho Falls Idaho
    100
    I searched the subject but nothing seemed to fit, so here we go, I just rebuilt the motor in my 85 200X when i put it back in the frame today it wouldn't start, it had spark so I cleaned the carb and still no luck, then I pulled the tank off to check the timing and while doing that I noticed a bad connection on some wires, so I fixed them and it started right up, I got it to idle and let it run while I reassembled. I got on to go for a ride and made it about 30 feet and it started popping like it was missing and died, I pushed it home, it still had good blue spark, I cleaned the carb again, it has new gas and still nothing, so tonight I took my CDI and pulse generator of my other machine(which runs) and still nothing, no matter how much I kick or even if I put fuel in the cylinder it won't start. Please help this is driving me nuts I can't figure out why it won't start!!!
    Jan 2005
    RI
    2,530
    You might have jumped time. Did you tighten the cam chain after reassembly? Did you readjust the valves?
    Mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Aug 2004
    Idaho Falls Idaho
    100
    I will re-check the timing in the morning, I didn't do anything with the valves, could that be the trouble??
    Jan 2005
    RI
    2,530
    if they finally got nice and warm and tightened up on you, they may not be fully closing.
    DO them when the motor is cold, but not cold outside...like a nice 60 deg day is fine.
    Mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Mar 2003
    illinois
    33
    anybody know what the valves are suppose to be set at on a 83 200X?
    2000 400ex
    450R front shocks elka revalved rear shock w/linkage
    magura hydraulic clutch
    wrist wrester
    fmf powerbomb w/ WB R4 silencer
    440 kit (11:1)
    steering stabilizer
    tinner scoops
    pingry oil tank
    Merrillville,Indiana
    129
    valves are set at .003in
    Aug 2004
    Idaho Falls Idaho
    100
    Could the valves be giving me this much trouble though?? Howcome the machine ran fine earlier in the day and now nothing regardless of what I do.
    Aug 2004
    Idaho Falls Idaho
    100
    jeswinehart you were right, I was pulling the pulse generator cover off to check the timing and the little pin off the camshaft fell out when I took it off so i put it back on and retightend everything and it started right up!! Thanks everyone for all the help
