Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
Thread: holley 600 help
    mean350 is offline Just Too Addicted Arm chair racerJust too addicted
    uniontown pa
    472
    holley 600 help
    how do you set the idling on a holley 600cfm carb? thanks a bunch
    85 honda 350x
    78 honda atc 70
    84 yamaha 225dx
    03 honda cr 125
    57 chevy bel air
    79 shortbed chevy 4 in lift and 35"s
    PA
    3,515
    with the idle screw on the left side.....no joke
    if you mean the air screws what i do is turn them in slowly till the motor starts to stumble then go out till it stumbles and put it right in the middle
    WWW.HREATV.COM
    uniontown pa
    472
    thers only 1 screw for the idle then? i though it was the screws that are on each side of the carb,.
    85 honda 350x
    78 honda atc 70
    84 yamaha 225dx
    03 honda cr 125
    57 chevy bel air
    PA
    3,515
    those are the air screws
    WWW.HREATV.COM
    PA
    3,515
    http://www.holley.com/
    this will help
    WWW.HREATV.COM
    uniontown pa
    472
    thanks!!!!!!!
    85 honda 350x
    78 honda atc 70
    84 yamaha 225dx
    03 honda cr 125
    57 chevy bel air
    MO dx's Avatar
    MO dx is offline Just Too Addicted Arm chair racerJust too addicted
    palmerton
    532
    If you were closer thats what my specialty setting up carbs on hotrods.
    Feb 2006
    southern Indiana
    105
    Gently turn both idle mixture screws in until they bottom out. Back each one out 1and 1/2 turns. Hook a vacuum gauge to a full manifold vacuum source. Start the engine. Back each screw out the same amount until you get the highest vacuum reading. If you go too far, the vacuum will drop and you will have to turn them in a little bit. Then, set your idle speed with the screw on the throttle linkage.
    uniontown pa
    472
    which vacuum? i cant leave it running it revs so high
    85 honda 350x
    78 honda atc 70
    84 yamaha 225dx
    03 honda cr 125
    57 chevy bel air
    Feb 2006
    southern Indiana
    105
    A full vacuum port would be in the baseplate of the carb, like the port your modulator line runs to for an auto transmission. Is your whole problem the high idle? A vacuum leak in the carb to intake gasket will make it run too fast. Is the fast idle turning off when the engine warms up? Do you have an electric choke? Is your idle speed screw turned in too far? Your idle speed screw is on the linkade near where the throttle cable hooks up. Screwing it in simply opens the throttle. Is your throttle returning to the closed position? Usually the stock throttle cable bracket will not put the proper tension on the spring and engine vacuum will crack the throttle. If this is the case, holley makes a bracket. Let me know if you need more help.
    uniontown pa
    472
    there is no port in the baseplate of the carb. theer is just 2 of them on the side. the idle screw is turned the whole way out and it is not sticking anywhgere. its a manual choke. the throttle is returning fine.i dikdnt look at it whikle the engine is running cause the idle is so high. when i firdst fire it up it aint bad then it revs like crazy.
    85 honda 350x
    78 honda atc 70
    84 yamaha 225dx
    03 honda cr 125
    57 chevy bel air
    Feb 2006
    southern Indiana
    105
    Is your carb a single fuel line vacuum secondary? What model number is stamped on the choke tower? Is it 1850? You should have an 11/32 vacuum port on the base for the PCV hose and there should be a small port at the front of the carb on the passenger side. If you have the choke off and tap the throttle, do the rpm's come down? Your fast idle may be set too high. I would almost bet it's the fast idle or you have a vacuum leak. What kind of vehicle is this on? Is the carb new? Did you just install it?
    uniontown pa
    472
    no its not an 1850. its like 6... and no the rpms does not come down when i hit he gas. how do i adjust the fast idle?
    85 honda 350x
    78 honda atc 70
    84 yamaha 225dx
    03 honda cr 125
    57 chevy bel air
    uniontown pa
    472
    its a 6520
    85 honda 350x
    78 honda atc 70
    84 yamaha 225dx
    03 honda cr 125
    57 chevy bel air
    Nov 2006
    southern oregon
    2,338
    Quote Originally Posted by mean350
    The fast idle is usually part of the choke linkage... shouldnt matter unless the chock is engaged. It sounds to me like a your throttle is hung open(most likely improper cable or bracket), or your curb-idle is just set way too high. If you look at the lingage you will see the curb-idle adjuster... then peek down inside the carb and look to see if the throttle blades are closing. the secondaries can hang open too... After you get it to idle down to a reasonable level... then follow the methods described by bondoboy for adjusting the idle-mixture adjustment screws... That is how I do them...and probably the easiest for those that havent developed a feel for it.
    2-stroke lover
