Thread: lone star bearing carrier
    Mar 2003
    Barnesville,Ohio
    2,298
    my carrier in my 350x is destoryed.
    i found this on ebay: http://cgi.ebay.com/ebaymotors/LONE-...spagenameZWDVW
    if i get this, do i also need the 86 350x sprocket hub? also, will this carrier accept all balls bearings when they need replaced in the future? thanks
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    kb200x's Avatar
    kb200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    KY
    295
    Quote Originally Posted by trikerider2oo7
    yes you will need the 86 sprocket. Not sure about the all balls bearings? Dads here on the board would know he sells them.
    86 350x "O' Smokey"
    83 200 auto X
    84 200x
    85 110
    82 70
    kb200x's Avatar
    Aug 2005
    KY
    295
    I just noticed you said sprocket hub. All you need is the sprocket from a 86 the bolts are sunk in on the 86 sprocket unlike the 85. The sprocket hub is built on the axle both years are the same.
    86 350x "O' Smokey"
    83 200 auto X
    84 200x
    85 110
    82 70
    Mar 2003
    Barnesville,Ohio
    2,298
    thanks kb200x...i tried asking the seller about the bearings but he must not have understood the question. anyone know about beaings other than lone star ones fitting in this carrier? thanks
    1984 Honda 200ES
