Results 1 to 2 of 2
Thread: Help my head leaks. Hehe...
    Apr 2003
    4
    I have a old crappy 185/ with 200 engine on it i pulled it out the bushes and got it running. The reason i parked it was becouse 2 years ago or so i got someone to overhaul it. They instaled a wiseco 12:1 piston. I put on a 200x carb and a few other mild performance parts. Well After about a month the head started leaking. So i parked it all winter becouse i was told it would mess the valves up if it sucked in cold air. Um well what can i do to fix this. I am too lazy to take the motor out the frame and put a new gasket in. so i was wondering if theres any kind of silicone i could slab around the head and let that be that?
    That is if retorqing doesnt work. if i cant it fixed other than it using a little oil should it mess anything up? I think i spent around 4-500 rebuilding this thing. Really its a new motor top to bottom. New head/jug/piston/timing chain name one thing in that motor and ive probaly replaced it.
    FullBore is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    You could try and nip it down a little with a torque wrench, is that doesn't work it needs a new head gasket and maybe head skimming if its a bit warped.
    Nat
    1979 Suzuki TS100
    1984 ATC70, Broke
    1984 ATC110, Repainted and Rebored.
    1990 Suzuki SJ410
    Unsuspended Antics.
