With the Wrench Report mod that uses an open airfilter (airbox removed) does the Energy Induction/boost bottle get removed also?
thanks for any input....
1985 black & red Tri-Z
2003 black & yellow Banshee
you can leave it. I tried both and I didnt see any difference!
Original 85 TriZ owner![]()
Certified NASA welder PM me if you need any weldingI do extended swingarms and everything you can dream of
Three is Always better then four, unless its with women then four is better then three
Thanks, that is good to know.
Has anyone used and had good luck with any other air filter besides the K&N RC2000 that is mentioned in the article?
try a uni four inch long foam filter $11
Orange Shee, that's what I was considering. Off the top of your head, do you know what diameter I need?Originally Posted by 03 ORANGE SHEE
there is no diffrence running the air box with no lid VS the clamp on.. it will just cut down on cleaning the filter..and you will be able to run in wetter conditions..something nathen NEVER does...I have done both with no diffrance other than cleaning the filter every time I rode, Witch get Old after the first 2 rides...
My air box is messed up, so I was hoping to ax it all togheter and use a clamp on filter.
