Thread: 1974 atc 90 info
    Jul 2006
    western ny
    3,366
    1974 atc 90 info
    i need to know if i can use a ignition coil ( the coil with the plug wire) off a 84 125m with a engine out of a 74 atc 90 ? i also need to know where the condenser mounts. any help would be great.
    GIT IT RAAAGGGGG !!!!
    Howdy's Avatar
    Celina, Ohio
    10,079
    The 74 is 6 volt system, and the 125m is a 12 volt system. You will probably burn up electrical stuff if you swap it.
    Howdy
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Jul 2006
    western ny
    3,366
    ok then i will need a list of everything i will need to make this 90 engine work in the 125m frame.
    please help me out guys.
