Just picked up a 335 l/c 2 cylinder polaris snowmobile.![]()
Almost did not get it cause its a polaris. But this snowmobile is going where no snowmobile around here dares not to go. Strickly on water. Not a water crosser but as a sea doo hence the "model" name Cea Me Goo. It has a artic cat style track on it with pvc piping for slide rails" never thought of that" but clever none the less. This thing is too float on its own not running. I think this would be trick. And if it is bottom bound then its just a polaris and thats 1 less pos. But I have faith. The motor runs great and the belly pan is all plastic and in good condition. It has more then 130 psi in both cylinders so it is on its way out. Buddy says its a 1980 340 txl. I have no idea. It has a blue trunk in the back. It has its heat exchangers under the floor boards" very unusual". It has a sticker that is near the back that says txl but can look like lxl. It has the normal style front suspension leafs and shocks.pull start only. It could have been purple but it might not have. I have no pics yet but I need some help with this one.
A good pic of what it looks like would be great.
