Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Thread: carbon fiber rad shrouds?
    Aug 2006
    NW Ohio
    1,043
    one more question though. what type of carbon fiber do i use? will any carbon fiber cloth work? or is there a special type i need?
    ATC500AF
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    I looked into this a while back and from what i learned in a few days worth of research, in order to get the full benefits of using CF (Light weight, and strength) you needed to make the mold where it can be pressed, to remove as much of the excess resin as possible. The resin, from what I've read, is what makes it semi-brittle and heavier then a well made pressed piece.
    Aug 2006
    NW Ohio
    1,043
    thanks for the info i was thinkin about a double sided mold myself
    ATC500AF
    Aug 2006
    NW Ohio
    1,043
    well i got into the prject by getting prices and well just does not seem economical. so i contaced maier to see if they would make a set of carbon shrouds and they said yes but i need to order 10 sets. who all is intrested?
    ATC500AF
    Live Oak, FL
    15,070
    Depending on the price, I might be in I'd make a new thread in the Research/Development forum to get a little more attention.
    dont know if you know this but the maire carbon fiber is just a print not the real deal..http://www.maier-mfg.com/ezcart/products/50968-.jpg
    May 2005
    Dorset United Kingdom
    1,408
    This is exactly the barrier me and my dad came up against when making bodywork for a lightweight race car, found that it would be alot of work to get the weight savings for the cost, ended up with fiberglass and shaped Aluminium instead
    85 Tri-Z "Rumble Bee"
    85 250R "Red Rocket"
    83 200X "Flat Tracker"
    Aug 2006
    NW Ohio
    1,043
    Quote Originally Posted by bryan raffa View Post
    yes i know but for the look and only around $50 a set its alot cheaper than $100 a shroud.
    ATC500AF
