Results 1 to 7 of 7
Thread: t3 reeds?
    Jul 2006
    galway ny.
    534
    t3 reeds?
    ok gonna be buying new reeds for the 85 t3,but what will be better vforce or vforce3? anybody got a clue?they are the same price 141.00 but i need to no what is better any t3 guys no.please need to find out before i spend the buckerroos''
    85 tecate 86lt250r
    85atc 200x
    Ontario, Canada
    457
    since you haven't gotten a responce,
    from an ad for the G3 power curve reed assy. mind you it doesn't list the V-force3 but does list the V-Force;
    G3 Power Curve................................71.40 CFM
    Boysen RV.........................................64.68 CFM
    Honda 250R stock 6 petal.................54.60 CFM
    V-Force............................................. 53.00 CFM
    Pyramid........................................... ..51.00 CFM
    Yamaha YZ 1989 6 petal...................50.40 CFM
    all were under the same conditions
    i think it would b safe to say that the V-Force3 would be a big improvement of the V-Force!
    '85 ATC 250R
    FMF Fatty & Power Core
    Boyesen Rad Valve
    38 PWK A/S
    K&N w/PF (next purchase)
    LSR +4 Axcaliber axle
    LSR Duel row bearing carrier
    DuraBlue Anti-fade (to be installed)
    13/36 sprockets
    '85 ATC 250R
    Parts trike (maybe future build?)
    Newfoundland
    5,280
    Just get a set of Boyseen carbon reeds and have the head milled.
    Newfoundland
    5,280
    That is unless you would rather swing the cash for port work! Best bang for the buck! Having the head milled, (yamahondaman) and some good mid/top port work done. (yamahondaman)
    I do believe you will need a replate after the port work though.
    Sep 2006
    Shreveport, Louisiana
    888
    I am currently running the VForce Delta2, the old style, and they are quiet a kick in the pants. surprised to see it down on the flow charts above. If I was buying again, I'd buy the Delta3 reeds. Chris
    >>>>>>>>>>>>>>>2007 Yamaha Raptor 700R>>>Cross Country Racer<<<<<<<<<<<<<<
    www.myspace.com/bluelionracing
    Support my 2009 sponsor:
    For all your ATV suspension needs.
    Mar 2004
    Gettysburg PA
    498
    well companies are alwasy doing new tests and improving thier products. i realy doubt they would put out a new product if it had less proformance ganes than the last. I have the delta3 reeds on my 250r atc and i realy like them and you dont have to adjust the delta3 like you do on the others.
    My Trikes
    1985 250sx
    1986 250r
    Parting out 85 kxt tecate pm me with your needs
    Jul 2006
    galway ny.
    534
    well im going with the vforce3 reeds i think, with that the pvl ignition new 38pwk carb it should run good its got alot of power the bottom end is strong its a good 85 tecate, and when the day comes when it dies i will rebuild her hard''thanks for the info guys its always helpful''
    85 tecate 86lt250r
    85atc 200x
