Results 1 to 12 of 12
Thread: 300EX BIG BORE 250SX MOTOR? - Can it be done?!
    Aug 2005
    Lockport, NY
    2,395
    I have seen this mentioned briefly discussed in threads here and there. Cold hard facts, can it be done? I have purchased a used cylinder,head and camshaft. I am planning on building a motor for my sx and figured if i could get the cylinder and head cheap enough i would see if it can be done. I would like your opinions. I know some guys will say why wouldnt you get a 200x or 350x. I love my sx. Just want a narly motor in it. I know im not the only one.
    Some one even mentioned using the 300ex cylinder and piston with the stock 250sx head.
    Plan of Attack
    supertrapp exhaust system
    300ex topend
    High comp 300ex piston
    WebCam with chrome moly valve springs
    oew timing chain
    oem valves
    oem guides
    350x carb
    open airbox
    K & N filter
    LETS HERE IT BOYS......
    Jul 2006
    not the 300ex but the trx head and cyl combo, also with a few mods (jackshaft assy) you can jsut put the complete trx 300 motor in the sx! I got one and think when my 250 es craps out i might put the top end on .
    Aug 2005
    Lockport, NY
    2,395
    sykolincoln you are correct. I meant the trx 300. That is what i purchased.
    Jul 2006
    yea do a search for 300sx and should find the thread of the conversion
    springville, PA
    6,185
    Yeah but that thread was about putting an etire trx motor into an SX, he is just ging to use the top end.
    I would say look at your head bolts on the SX then compare that to the trx cylinder and measure, if the hols line up you might be golden
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Jul 2004
    CANADA
    80
    You will not get more cc's by putting the trx300 cylinder on your sx bottem end because the 300 and 250 have the same bore , the difference is in the stroke
    1981 ATC250R
    2004 yzf450 with a banshee engine
    1983 atc200
    1989 Quadzilla
    1991 LT80
    springville, PA
    6,185
    ah yes very true so i wounder if you can just throw the high comp trx piston in the SX ?
    Nate
    R.I.P HRR
    Jul 2006
    no shiz?? didnt even care to look at that! well... damn.... oh well. at least I got extra parts lol.
    Aug 2005
    Lockport, NY
    2,395
    sh!t i never even thought of that. damn. well the thought was there. Hmm. High comp 300trx piston.......... now thats interesting
    Jul 2004
    CANADA
    80
    you can't use the trx piston in the sx either because the pin hole is alot higher on the trx , i can get a pic of the difference if you would like .
    Later jeff
    1981 ATC250R
    1983 atc200
    1989 Quadzilla
    1991 LT80
    Aug 2005
    Lockport, NY
    2,395
    lets see the difference. this is interesting.
    Howard's Avatar
    Howard is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Memphis, Tn
    288
    i wanna see too.
    1985 250ES ATC
    1985 200X ATC
    1984 250R ATC
    1983 LT-50
    1991 LT-80
    1996 YFB-250
    >->->->Hgoody77@yahoo.com
