Allright, getting my tri-z put back together and want some help reccomending a carb. They come with 32mm Mikuni's stock, right? And i've heard of using a carb of a 250R. What brand/size carbs are stock on the 250R? Should I stick with 32mm or go with 34mm ir 35mm? It's basically a stock set up but with an open air filter. Any reccomendation for jet size other than a little test and tune? Any other carbs I need to look at? Was thinking mikuni flat slide, they are cheaper than the PJ or PWK carbs, or should I go with those? Anyways, any input is appreciated, thanks
So a new silencer would be in order? the current one's a little crusty looking anyways, anything else i should look into? I should prolly replace the fuel lines while i'm at it, what size/type should i use?
