Results 1 to 15 of 20
Thread: trx and atc brakes interchange?
    Jan 2005
    Jones, Michigan
    1,821
    Hey guys do the trx 250r rear brake calipers interchange with the atc's? I would think so but i dont want to buy one if it dont fit.
    Kevin
    - Chick McGee
    -1985 250sx
    - 1986 atc310R drag bike
    - 1981 110 chopper.
    - 1985/6 350x
    - 2-84 atc250r's and 1 83
    - 2002 trx400ex
    - 1985 atc 250r
    -1985 atc70 WTB PARTS
    - 1985 tecate
    Mar 2007
    Buffalo, New York
    68
    The TRX250R rear caliper in the Honda parts catalog has a part number of 43209-HB9-008, showing application of 86-87 TRX250R only. By the book no, but perhaps someone knows if it will bolt up.
    eddie pettengil is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2007
    nh
    297
    I bought a new caliper from CAL-ATV for my 86 trx. With the parts from my old stock 86 trx caliper and parts from my stock 86 atc caliper, I built a caliper for the atc and had no problems bolting right up. Cant remember what parts came from what, but I think they are the exact same. Good luck
    kb200x's Avatar
    kb200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    KY
    295
    Im pretty sure you can use almost any rear caliper from a quad and make them work for a trike as long as you have the mounting bracket. I am sure the honda calipiers are the same they just have different mounting brackets. I have Niffin or Nissin (I am unsure of the spelling?) caliper's on my 350x that I am not sure what they came off of? So others will work.
    86 350x "O' Smokey"
    83 200 auto X
    84 200x
    85 110
    82 70
    3leggeddog's Avatar
    Nov 2004
    yes they are the same.the only thing that is not is the master cylinder.the quad one wil not work for the atc
    Jan 2005
    Jones, Michigan
    1,821
    sweet. I did find a whole atc rear end im bidding on WITH a brake caliper.
    - Chick McGee
    -1985 250sx
    - 1981 110 chopper.
    - 1985/6 350x
    - 2002 trx400ex
    - 1985 atc 250r
    - 1985 tecate
    Jun 2004
    potsdam ny
    1,227
    are you sure the quad master wont work? im pretty sure they will...also the only difference in the calipers in the way they attach to the swingarm, if you look at an 86' and an 85' the 85' uses an extremely short arm compared to the 86+...but the calipers are exactly the same....
    Jun 2003
    englishtown NJ
    2,676
    I have both, the quad masters won't work.
    InPiEcEs's Avatar
    InPiEcEs is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2004
    Northeast Wisconsin
    378
    I have heard that if you use the ATC pushrod on the Fourtrax master, it will work............I have not tried it though.
    One piece at a time. Status: The Beast is Done..06-23-07
    Back in the saddle again
    Currently owned rides:
    My sleds, and.........
    1995 CBR600F3
    1976 Kaw 400 triple-smoker......SOLD
    1986 250R...owned since 1990
    06-23-07........the R is finally done!!!
    ESR pipe, Aktive reeds/CR cage, 38mm PWK, +4 Dominator
    mild clean-up porting, an open K&N, CR and YZ calipers.......among other things
    Jan 2005
    Jones, Michigan
    1,821
    well my old man has a master thats matches up with my 85 R master. It looks identical except the lever that is on it isnt bent like the atc's and it has a number 2 on it while my atc master has a number 1 (or vice versa) I just won that complete rear end with caliper for an 85 R for $50 so im good to go now.
    - Chick McGee
    -1985 250sx
    - 1981 110 chopper.
    - 1985/6 350x
    - 2002 trx400ex
    - 1985 atc 250r
    - 1985 tecate
    3leggeddog's Avatar
    Nov 2004
    the trx master won't bolt up to the atc frame.the way the brake line comes out of the trx is different also.maybe some years are different,but the trx master i had,would not work.
    good score on the rear end kev!!
    Jan 2005
    Jones, Michigan
    1,821
    Quote Originally Posted by 3leggeddog
    its filthy but he said the axle is straight and the caliper works good. I hope the pins arent stripped out
    http://cgi.ebay.com/ebaymotors/ws/eB...m=230113055257
    - Chick McGee
    -1985 250sx
    - 1981 110 chopper.
    - 1985/6 350x
    - 2002 trx400ex
    - 1985 atc 250r
    - 1985 tecate
    3leggeddog's Avatar
    Nov 2004
    now you just need to send that swinger to me for a stretch!
    Jan 2005
    Jones, Michigan
    1,821
    i have 3 or 4 extended swingers but cant use any of them. Every single one of them they extended but didnt move the little peg on the side for the brake stay. Maybe their is some way to use them, i dont know. i have a chrome +1.75 i think then a like 2 or 2 1/2 and a 3 i think I cant even remember
    EDIT I guess when you use the right combination of brake stays and things it actually WILL work Now im not sure which swinger to use. I like the looks of the white one on my 85 R but I Extended the white ectended one and it looks a little whacked Then it has like $40 in powdercoat on it
    Attached Thumbnails Attached Thumbnails 250r swingers 1.JPG   250r swingers 2.JPG   250r swinger 3 White.JPG   85 250r with new plastic left.JPG   85 250r with new plastic right.JPG   85 250r with new plastic back.JPG
    - Chick McGee
    -1985 250sx
    - 1981 110 chopper.
    - 1985/6 350x
    - 2002 trx400ex
    - 1985 atc 250r
    - 1985 tecate
    3leggeddog's Avatar
    Nov 2004
    i'd run that whute thats on the bike,looks sweet!!!
