Results 1 to 3 of 3
Thread: REBUILT ATC 110/// petrol comin from the overflow
    Jun 2006
    *Edited*.k
    hi all i have just rebuilt my atc 110..and am now ready for starting ..but when i turn the petrol on it just keeps flowing out of the overflow pipe ..i have put a little petrol in the plug hole to see if it will start and it did ...
    so how do i stop it overflowing and let the plug get fuel as the plug is dry after pulling
    if someone could tell me what to do when i get the carb off
    thnx ryan
    Tionesta, PA
    5,747
    sounds like either a stuck float, or a bad needle valve,
    You need to tear apart your carb and check it out.
    Frewsburg NY
    1,169
    mine did the same. tear the carb apart and clean your float and blow it out with air and that should solve your problem
