Results 1 to 15 of 22
Thread: How to pull a 250es motor? NEW PIC'S
    yarmouth Nova Scotia
    88
    Hi guys just looking for some info on how to pull the motor out of my 86 250es. Ive undone everything, mounts, wires etc but I cant figure out how to seperate the driveshaft from the angle joint (that i dusted, see thread "good friday?"
    I thought that the drive shaft was splinned and it should just pull out but I may be wrong. Any ideas?
    86 250es
    "cant win" "my mom says im cool"
    Pull the rubber boot back and use a large pry bar to slip the driveshaft backwards towards the differential.
    BUT!! I am saying this based on the SX, I have seen some Big reds with a solid driveshaft the would require pulling the axle and diff I imagine...
    Do NOT pull the shaft out of the engine by the allen bolts, bad thing to do...
    88
    does anyone know if the final drive assm has to be removed?
    86 250es
    Michigan
    1,144
    I have just restored my 85 BR and when I was taking my BR apart I tried as the manual said to slide the drive shaft back towards the differential but it wouldn't work that way. I finally had to take the whole rear assembly off which I had planned to do anyway.
    88
    would it help if i changed the drive shaft angle? Imean it i tlet the rear end hang with the bottem of the trike supported on a jack?
    86 250es
    Eastern Long Island
    1,688
    I have allways just pulled the rear. It makes it so much easier.
    Lots O Trikes!!!!!
    Columbiaville, MI.
    1,508
    hublake you finally get your all completed?
    MDR Racing
    LONG LIVE SANCHEZ RACING
    88
    Is it a big job to pull the rear?
    86 250es
    florida
    2,328
    NOPE all u have to do is remove the rear wheels and the axle then the final drive comes off with 8 bolts
    Kentucky
    2,294
    Quote Originally Posted by 200xman
    I agree, and it's not much of a hassle at all. It will go alot smoother if you do it that way.
    Tionesta Trikes ATC 450R
    86 250R
    86 Tecate-3
    83 ATC 70
    85 Big Red
    81 KLT 200
    85 250SX
    88
    if i remove the 4 bolts on the drive shaft tube(were it meets the rear end) ant then the 4 bolts on the right swing arm (were it joins to the axle) I should be able to put it apart? Oh also the lower shock bolt removed
    86 250es
    florida
    2,328
    yep ..no need to remove the shock bolt tho=
    88
    hey man thanks alot. I guess i better get started lol
    86 250es
    88
    NEW PICS the damage LOL
    86 250es
    Feb 2007
    Nova Scotia
    18
    Looks like you did a number on that one bud. I got a new driveshaft for ya.
