Results 1 to 13 of 13
Thread: Problems with 90 rm 250
    Greiver430x's Avatar
    Greiver430x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Swiftwater, Pennsylvania, United States
    444
    My bike will be running fine then just die and not start up. after kicking for a while or trying to pop start it ther will be gas on the plug. If it sits for like a day you can go back out and it will run fine for 10-15 minutes then die again. UUUUGGGGGHHHH!!!! Any ideas??
    2 1978 Yamaha xs750 specials
    2008 Kawasaki KFX450R
    Powermadd handgaurds, K&N, UM Full skidplate,Dg nerfbars with heelguard and pegs.Maxxi RAZR's all around MORE TO COME.
    1987 Suzuki 230 Quadsport, all stock and one mosquito fighting machine
    Black Booger Crew member
    G-MAN-1 is offline Just Too Addicted Arm chair racerJust too addicted
    Ok
    Its The Stator Its A Known Problem With That Bike. I Have Had The Same Thing Go On One Of My Old Bikes.
    444
    now it runs for a couple of seconds and dies
    you can kick it and it runs for a second and shuts off still think its the stator? If so i can get one from dennis kirk for like 135 and change.
    Groundworx's Avatar
    Groundworx is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Tuttle Oklahoma
    421
    I had a 93 RM250 that would do that too. Don't rule your stator out yet, but check your plug. I know that sounds like a pre-school solution, but hear me out. The RMs have a really hot ignition. They will literally blow a cheap plug in just a few minutes. The original plug that Suzuki runs in those bikes are about $30. You need to run an 8 in it. A 9 is too cold and will only last a few minutes at best. I was told a 9 would work just as well, but I had to go with a hotter one. I would try that before messing with buying a $135 stator.
    Many quads for sale. 400EXs, Z400, 450s ect.
    444
    Pulled the plug its like new because i just put it in Its a b8egv (ngk) thats what it calls for its geting spark btw checked it. Did a compression test got 118 psi. How do check the stator i have a multi meter to do it just not sure how.
    Groundworx's Avatar
    Tuttle Oklahoma
    421
    U got me then. I think ran a B8HA in mine. Mine would still get spark, but I guess it wasn't a good enough spark to keep it running. Sorry, I don't know how to check a stator. I have never had and trouble with one. (knock on wood)
    daputz is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2004
    a proud cheese head
    207
    118 is low, I'll get the factory spec tomorrow.
    As for it shutting down, is it overheating and seizing? Do a leak down test.
    Groundworx's Avatar
    Tuttle Oklahoma
    421
    I forgot about that. My pump seal went out and I didn't know about it. When my bike got too hot, it would shut off too. That should be something else you should check.
    444
    Figured it out my friend mixed my gas wrong , while using a ratio right . Running fine again , if I want it done right gotta do it myself.
    Mar 2007
    Williamsport, PA/Lycoming county
    829
    haha don't you just hate it when its the most simple thing that was overlooked. lol
    My Stable:
    2007 ARCTIC CAT DVX400
    07 Kawasaki Ninja 650R--My Baby--
    Honda 200M with a 200E engine and 200S front end- A true stump puller SOLD!
    Scars are a reminder to the old of all the dumbshit they did while young - Me
    illinois
    743
    just a suggestion- the b8/9/10 ev plugs are *Edited**Edited**Edited**Edited*-
    the (ev)series are a wast of money- replace them with the (es) series if possible
    i swear the ev plugs i have used didn't last more than a couple rides ,and my bikes run great-
    444
    yeah the dude at the suzuki dealer said the same thing and at seven bucks a popfor the b8egv ill go with br8es for like two bucks.
    Dec 2006
    New Brunswick
    41
    Why stop there?
    Go get a NGK Iridium Xtream plug BR8EIX
    17.00 bucks here ,and worth every penny
    1984 Honda ATC200M
    1984 Honda ATC200ES
