I installed a DIAL A JET in my stock carb, now my issue is this, it will start right up idles perfectly but them seems to run out of fuel, is this caused by the DIAL A JET fuel line I installed on the float drain by chance?I am assuming it needs to be filled up all the way to allow fuel to get to the adjuster-is this causing my floats to stick by chance?I can rev the motor up, it will run then die out like the bowl isnt filling up/running out of fuel when a demand is there, anybody help me here?
