250r bottomend rebuild and upgrade
Well I guess this is just how it goes. I was doing some last min repairs on the 85 250r before going to the sand on tuesday and thought I would do a little more digging. Pulled the reed cage and everything looked good, stock but good. So I was looking at the piston and it had a big scuff on the side. No big deal I ordered a .25 piston 2 years ago just get it bored we will still be set for tuesday. Pull the jug yep time to rebuild the top end. So I was looking the rod and crank and what is this? A crack in the crank? Oh heck! Now I think I will rebuild the bottomend when I get back. The plan is a hot rods crank/rod and some port work and the new piston. Better reeds/cage and a 38mm carb(cr 250r right?). So now for the question part of the post. I see there is a stroker crank but it is listed for newer trx 250rs, I am guessing this is something to do with the short rod long rod thing. Can I use this crank if I get the right piston? What special machining is required? Worth the work and money? I was looking at the duncan porting but can't decided between the NATIONAL Cross Country (low end) and the NATIONAL Midrange (midrange). Has anyone used eather of these? I do a lot of hill climbing and woods and trail riding but do ride in the sand 1-2 times a year. I think the low end would fit the best but don't want to be still behind the 700 raptors out of the hole after the build up. Reed suggestions? Still going to use my fmf pipe and silencer for now. I can't imagine how it run even with a rebuild cause I thought it ran good wore out!
Thanks Guys
There is Nothing too nice to be hot rodded
85 250r (On going build up and rebuild) Ported Cylinder, 36mm carb, New Crank, Rod and Piston FMF Exhaust (for now)
04 400ex, Duncan Racing Exhaust (,wifes)
80 Z-28 (5 year + 10 to 1, Full Roller 427 + .060 (440) build up ) 475 hp at the rear wheels running 7.22 1/8s on old slicks.
