Thread: 85 350x rear sprocket question
    hazard's Avatar
    hazard is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2007
    Iowa
    162
    ok currently im running stock gearing on my 85 350x, 13 tooth and 40tooth sprockets, i am running 22x11x9 maxxis razr 2 tires, and im thinking i want to get a little more low end and sacrifice some top end, i understand going to 20 in tires would do this but i dont want to go with the smaller tires, the type of riding i do the stock sized 22's work great. but everywhere i look for sprockets they dont offer any rear sprockets for the 350x over 40 tooth, and i dont wanna go with a 14 tooth front. so what im asking is i would like to try a 42 tooth and see if that works better for me, but i need to know what sprocket off of another application will work on my 350? please help me asap, and also if i went to a 42 tooth would i have to change the length of my chain which is 520x90??? thanks
    Thanks,
    Adam
    ______________________
    1985 ATC350X
    -86 engine and plastics, DG rcm full exhaust, DG grabbar, Moose Carbon Bar, Moose bark busters, UNI air filter, Regina chain, ECA rear brake caliper, 22x11x9 Maxxis Razr 2 tires
    1984 ATC250R
    -Project trike, needs top end rebuilt
    kb200x's Avatar
    kb200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    KY
    295
    Quote Originally Posted by hazard View Post
    I'm not sure where you can get a sprocket but if you go to a 14 front you are going the wrong way. Something Tim sr. shared with me about gearing 1 tooth on the front is like 3 1/2 teeth on the rear. What kind of riding are you doing that needs more low end on a 350x?
    86 350x "O' Smokey"
    83 200 auto X
    84 200x
    85 110
    82 70
    Mar 2005
    overton, PA
    5,257
    i have 12 tooth on my 350x and ended up throwign a few more lbs of air in the rear tires, sacrifice just a bit fo ride quality for a better gear ratio thats moere tight woods friendly.
    hazard's Avatar
    Mar 2007
    Iowa
    162
    worst part about a smaller sprocket on the front is it will make your engine rev higher which is somewhat bad i would think. dang it i was hoping someone would know more about this situation., but it seems most of you guys like em geared a little high with 20 in tires for dune riding and such but i dont do that so that wont work, we have put 20 in and 18 in tires on trikes and quads here at home and they dont work worth a hoot for our riding style, the 20s work good on quads but not trikes, IMO (im not bashing people who run 20's on trikes so lets not start that nonsense please) my friend has a i think a 46 rear sproket on his 85 350x cuz he runs 22x12.5x9 vampires on it, ill get some pics it looks sweet, but hard on clutch im sure, ill have to talk to him too see where he got that sproket, i dont want that big of one but he might know where to look.
    Thanks,
    Adam
    1985 ATC350X
    1984 ATC250R
    hazard's Avatar
    Mar 2007
    Iowa
    162
    sweet i went to sprocket specialist.com and found exactly what i needed thanx for the help guys but i got it all figured out now.
    Thanks,
    Adam
    1985 ATC350X
    1984 ATC250R
