Same Plug
Strictly wide open, less then 10 seconds of being off the throttle stop. Its a B9ES on a 250R, 39PWK 152 main 01 CR ignition. From the pictures I've seen around here, that bottom burn ring is about perfect I think, but the tip of it kind of worries me, although I've also read the tip does not mean anything. The plug I actually rode around on was about the same color as the burn ring the whole length of the porcelain. It was a little bit lighter chalky gray on the tip which I've usually associated with lean, but the side of the porcelain looked about the same as the burn ring on this one.
